Well i have another thread for this car in the pictures section i think.... figured i would make a "build" thread to post info for when i make some progress on this project. Anyways,
Originally the Summit Van had a 4g64 2.4L SOHC 8V engine. It was 5-speed and AWD. I think down in the US they were mostly called "Mitsubishi Expo"??? They were sold up in Canada as "Dodge Colt, or Eagle Summit" I was lucky to find a AWD one!
There now sits a 6 bolt 4g63t with a Galant VR4 W5M33 Transmission. It is still using the stock open diff rear end that came with it. I have a spare LSD rear end out of a eagle talon that i might try and install and also beef up the rear suspension crossmembers/diff mounts as the stock stuff looks pretty wimpy.
The A/C stuff has been removed along with the power steering as well. It is running a tucked 1G DSM wiring harness made to work with the Summits stock body harness.
Car is still under construction but the car runs/drives and stops under its own power now. Just little stuff to finish up on here like putting the interior/seats together and getting the Side mount Interooler/piping all in and mounted.
Currently the mods are
-6 bolt 4g63t out of a 1G Eagle Talon TSI
-Galant VR4 AWD 5-speed transmission (recently rebuilt)
-14b TDO5H turbo
-Walbro 255 HP fuel pump
-MBC (ball and spring)
-Full 3" Stainless Steel exhuast (from 1G AWD DSM)
-H&R springs (front) for DSM
-ACT 2600lb Clutch
PICS!
Ill keep this thead updated as i make more progress on this project and hopefully get it on the road in the next little while. (weeks, not months hopefully)
