It is currently Wed Jan 23, 2019 9:04 am
Post new topic  Reply to topic  [ 232 posts ]  Go to page Previous 112 13 14 15 16
PostPosted: Tue Oct 13, 2015 8:23 am
Yes, I got the plug and play harness and SD kit from ECM, all plug and play. Just got to weld in the IAT bung. Next I ordered a GM flex fuel sensor off ebay, the stock return lines fit over the stock GM sensor barbs good enough to just splice and go, super easy. Have plans to go to English Racing to get everything dialed on the dyno by the end of the month. Will be tuned on E-85 and I'll just let the flex fuel do the rest below that content.
PostPosted: Tue Oct 13, 2015 3:20 pm
Awesome, thanks for the info! I've been running E85 on my Evo's but have always just gotten them tuned on winter blend to be safe. This is a much safer sounding setup and sounds easy enough to install.
89 Colt GT
PostPosted: Wed Oct 28, 2015 5:58 pm
Had an awesome time at English Racing. Car did well but ran out of fuel. Enjoy the pics.
PostPosted: Wed Oct 28, 2015 6:41 pm
PostPosted: Thu Oct 29, 2015 9:33 am
that is awesome man :)
Warren
PostPosted: Thu May 05, 2016 12:28 pm
Replaced my leaky hotside with a less leaky one, FYI it's not a good idea to weld an internal gate shut by just the arm, you'll want to weld the flapper too or spring load the flapper arm otherwise it's pretty much impossible to get it to seal properly with thermal expansion characteristics. The car spools noticeably better now but we also changed the manifold and wastegate too so it's hard to tell exactly what was causing the lag. The car should perform much better on the track and dyno now. I think she could be good for 440-450 with the changes made with a much better power curve.
Debow aka Tony let me borrow his manifold and hotside for now as the ERL I got just didn't want to work with my setup :( .
PostPosted: Fri May 06, 2016 12:12 am
Looks good. Nice and clean engine bay
'92 Evo 1
'10 CTS-V
