Dodge colt gt 89 http://4g61t.org/forum/viewtopic.php?f=64&t=24419 |
Page 2 of 11 |
Author: | CaptainTonus [ Mon Mar 31, 2008 12:10 am ] |
Post subject: | |
Quote: You dont need a 4g63, the 4g61 is a awesome motor! It will rev higher then a 4g63, and also it will hold together better then a 4g63 cuz of the shorter stroke.
They rev just as high as a 4g63. Yeah, the 61t has a short stroke, but the crappy stock valvetrain will give out long before anything else, that and the lack of a decent drivetrain.
modify the 4g61 till it blows, then MAYBE put in a 63. |
Author: | ColtiXim [ Wed Sep 10, 2008 7:47 am ] |
Post subject: | |
Hello I m back ! With a small update from France ... Since 4 month i worked hard on my colt and this is m y futur setup . Suspension Kyb gr2 front and rear with new Kyb bump and upper mount from shockwarehouse.com . Short springs from H&R ref 29710 Outer track rod end from Camskill.uk Brakes front: drilled from Camskill.uk with pro act 328 pad from Rockauto rear: stock but news ... G stop goodridge 8 lines ref 26043 in command from Performancepeddler.com ...Thanks coltmax Odyssey batterie pc680 from motobatteries.com Water air IC from lindseyracing.com with flojet pump 3.2gl/m and clim evaporator and fan in stock place. MBC hallman evolution RX in cabin with 12 psi of boost i think ! Bcs and canister removed . New fuel filter and fuel pump rewired . Cath oil tank home made with a clim botlle Air filter putting in the fender with custom piping for more clearance . Custom outer pipe for the 11B OBX water coolant tank from Ebay AEM digital voltmeter and stainless Steel clutch line from racetechperformance.com Electric windows conversion After a paint job in original color code R52 this winter . Any question or help are accepted ... Many thanks for your help in this forum |
Author: | Flying Eagle [ Wed Sep 10, 2008 8:32 am ] |
Post subject: | |
Pictures of all of this sweet kit installed please, et S'il vous plait? |
Author: | ColtiXim [ Wed Sep 10, 2008 11:03 am ] |
Post subject: | |
In progress .... Please wait ! Maybe tonight on my signature or WWW With 2 or 3 questions in newbie tech forum for you ! Thanks for your time |
Author: | ColtiXim [ Thu Sep 11, 2008 2:43 am ] |
Post subject: | |
Hello Update on my signature below . Any suggestion are accepted thanks . Misubishi colt 1400glx 80 VS Dodge colt gt turbo 89 French language sorry |
Author: | Flying Eagle [ Thu Sep 11, 2008 9:26 am ] |
Post subject: | |
I would like to say that your car never ceases to amaze me! Keep up the hard/good work, it will give you a smile ear to ear when you get to driver this car in fully modified trim. Are your headlamps the standard ones from the US the car was imported with? |
Author: | ColtiXim [ Fri Sep 12, 2008 7:12 pm ] |
Post subject: | |
Yes but i have much time for modified this colt , i hope drive this winter after paint job ... For your information , after importation many glasses are changed because in europe different standard is requested . Only safety glasses and electrical connection securised ...Headlamps front and rear, blinks, bulbs and sockets etc ... |
Author: | TrevTec [ Sun Sep 14, 2008 5:23 pm ] |
Post subject: | |
I think he is using bablefish to translate |
Author: | ColtiXim [ Wed Sep 17, 2008 3:07 pm ] |
Post subject: | |
Hello For TrevTec, YES i use bablefish sometimes for translate ! Because my english language is very poor after 15 years ... I have a bad news for Goodridge G-stop 26043 ! This part has been discontinued from the manufacturer ... I hope obtains a Techna brake lines from www.horsepowerfreaks.com ! Any suggestion are accepted thanks ! |
Author: | HondaHunter [ Wed Sep 17, 2008 4:57 pm ] |
Post subject: | |
wow looking at the pictures and by researching H&R's german page, they still make springs for our car. PN - 29710-1 |
Author: | ColtiXim [ Fri Jan 02, 2009 6:58 am ] |
Post subject: | Re: Dodge colt gt 89 |
H&R 29710 global view Front left view with Techna brake lines Mit 810 fit perfectly ! Happy new year ... |
Author: | Evotistical [ Fri Jan 02, 2009 8:28 am ] |
Post subject: | Re: |
Quote: Hello
I think your web page is down
Author: | ColtiXim [ Sat Jan 03, 2009 9:22 am ] |
yes I know! I work for the best link maybe a myspace ... |
Author: | ColtiXim [ Wed Jan 14, 2009 5:22 pm ] |
Update for custom exhaust 3 P megan downpipe and 2.5 P final, resonator and muffler |
Author: | 89D15CRX [ Wed Jan 14, 2009 6:37 pm ] |
^ That looks REALLY good! Where did you get that exhaust at? I think we'd all like to know. |
Page 2 of 11 | All times are UTC-05:00 |
