It is currently Wed Oct 22, 2025 5:43 pm
Post new topic  Reply to topic  [ 123 posts ]  Go to page Previous 1 2 3 4 5 69 Next
 Post subject: Re: '89 Summit LX
PostPosted: Tue Mar 29, 2011 10:00 am
The bosses for the oil squirters are already drilled and tapped. Currently the car has plugs with crush washers in said bosses. As far as I know it came from the factory this way. I know John and Aaron did not have any bottom end engine work done and I do not think Rob had anything done to it. The hardest part of putting the squirters in will be dropping the oil pan.
PostPosted: Tue Mar 29, 2011 1:15 pm
You work quick. Nice to see the car is in good hands.
PostPosted: Tue Mar 29, 2011 1:37 pm
Thanks man. Everything that has been done so far has cost me nothing. It is basically the set-up I had on the Galant that I will not be using on that car anymore.
PostPosted: Tue Mar 29, 2011 2:11 pm
Got a built 2.0 for you when your ready. :o
1989 Dodge Colt E [4g63T]
2005 Saab 92X awd-turbo :)
2003 WW EVO8 FlexFuel
PostPosted: Tue Mar 29, 2011 8:12 pm
hey man we need to get together so i can take a ride in this beast!
PostPosted: Wed Mar 30, 2011 7:32 am
HAHA you can ride in it again when I get it tuned better.
If the 1.6 dies anytime soon I will be putting my built 2.0 from the Galant in it. Eagle H Beam and Wiseco 1400HD, BC280, JMFab SMIM, 25g MHI turbo and so forth. Would make that poor Scummit scream.
PostPosted: Wed Mar 30, 2011 8:57 am
Do it now! Why wait
PostPosted: Wed Mar 30, 2011 9:11 am
Toss it in. More work to do a headgasket on the 61.
PostPosted: Wed Mar 30, 2011 9:27 am
Then what should I do with my GVR4? Rebuild the 1.6 and put it into the Gaylant? LMAO
PostPosted: Wed Mar 30, 2011 9:37 am
Can't have your cake and eat it too haha
PostPosted: Wed Mar 30, 2011 9:38 am
Oh but I can and will. 600whp GVR4 and 300hp AWD swapped Scummit. Not difficult by any means.
PostPosted: Wed Mar 30, 2011 9:59 am
The blocked oil squirters must be a 4g61 only thing, I've honestly never heard that before. I know every non turbo 4g63 I have ever seen was not drilled/tapped for oil squirters. There were dimples there but thats it. Keep us updated on that.
PostPosted: Wed Mar 30, 2011 10:26 am
Yesterday I received the wheel spacers I need to put some Mazda RX7 FC 4 piston fixed aluminum calipers on the Scummit. Since I will be AWD swapping it in the future I am also putting on GVR4 spindles and CV shafts. The ROTA Slipstreams did not clear the outer "pots" of the calipers and at least a 20mm was needed to push the wheels out far enough to clear the calipers. I bought 25.4mm(1in) bolt-on spacers off eBay for $75 with free shipping. They are hub-centric and very nice pieces.
The rotors I am using were given to me by my friend Tim(trooper) and were originally multi-lug 5 lug rotors. In order to make them 4 lug I needed to drill one hole and widen two others. Once this was done I was able to test fit the calipers on the spindles.
Using an angle grinder with a thick grind wheel I made the mounting surfaces of the caliper flush with the spindle and "pushed" the flat mounting surface of the spindle back. Then I cut half of the top mounting ear off.
To make the adapter plates I started out with thin cardboard that I gradually cut and shaped until it fit then traced the shape onto the 3/8" steel I am using. An hour of grinding and cutting later and the piece fits as it should.
It was late when I finished cutting this piece so drilling the holes for the bolts will come later. Here is a picture of the slot I cut into the bumper for the 3" muffler-back exhaust I hung.
PostPosted: Wed Mar 30, 2011 10:28 am
I did not think it would have blocked off bosses either. My experience has been the same as yours: turbo block = oil squirters; nonturbo block = absolutely no oil squirters ever. The oil will be changed this weekend. I will take pics of the blocked off bosses and pics of the squirters once installed.
PostPosted: Wed Mar 30, 2011 12:18 pm
looks good man
