I didn't snap any pics, unfortunately. It was -10*C in the garage, so I had to move fast, lol.
Comparing pics of the DSM hinge to the stock colt hinge makes me think they're a direct fit, even though the part #s are different. I was going to try one, but got too impatient to wait for the junkyard to open (closed for christmas)...and I prefer older-school methods. If it's broke, take it apart and fix it
![:)](./images/smilies/icon_smile.gif)
Basically, all I did was grind the round 'cap' off the hinge pin, and punched it out. Due to sagging for so long, the pin had deep grooves in it on one side, where it wore down under the weight of the door. It's 5/16" (8mm) in diameter, but every bit of steel rod/bolt/pin I could find at the local industrial supply place were all 1/32" too small (even though listed as 5/16"). I tried a few things, but everything was too loose. I fired up my welder, cranked up the heat, and laid a few light beads in the grooves, to fill them back up. Then I took a grinder and re-shaped the pin, polished it a bit with some emery cloth (although the bushing is bronze, so it wasn't super necessary IMO), and tapped it back in. The pin is supposed to be immobile in the hinge, so I put a tiny tack weld at each end. I can always grind it down if I have to remove it again.
Over the holidays I may order a 1G DSM hinge repair kit, since they apparently exist, and see if those pins & bushings would work. Any DSM hinge I grab from the yard is probably going to be droopy too...those doors are HEAVY, lol.
