It is currently Sat Apr 27, 2024 5:17 pm
Listen to this..
So my crazy flowing exaust is giving me boost creep problems right. Well, my turbo ate a piece of rubber(dont ask) and I take it off and take it appart to put a new wheel on it. I figure while I'm in their, and porting stuff, I may as well open up the wastegate port a bit. Well, that I did, and know I can only get 9psi!! MY Q is, is that the proble, or could it be the actuator? I put one on that I found in the garage b/c the one that was on their broke a support. Any info would be appreciated. Thanks
jP
bad actuator.......
Geoff
Mach V
I have one for 50 bucks.. If you want it, let me know
Geoff
Mach V
PostPosted: Sun Dec 08, 2002 3:51 am
Na, actuator is good. It seems that the wastegate is just super efficient now. I found I just need to bleed much more boost to get the same , well max boost. I have it set at 16psi, and their is 0 creep. Guess I just did a good job of porting
