It is currently Sat Apr 27, 2024 2:52 am
I was lookin into buying an A'PEXi super afc and I thought I'd consult you guys first!
Question number one:Is it easy to install?
number two: What does it permit you to do, in other words, how much richer does it permit you to go?
Number three: Does it allow for the use of bigger injectors...if so how big?
number Four: I was on there site and it said that it would allow certain cars to run an open blow off valve, and that it corected for the loss of air and kept the car from stalling when you lift off the throttle, is this true? does it work the the factory BOV?
Thanks for the input!
Dan
10.50@145
The S-AFC can be used in the mirage. Most likely you'll use it to lean the engine, not richen it. Unless you have some weird setup. If you try to make it run richer you'll most likely make the ECU get into Fuelcut.
The new AFC may allow you to vent to atmosphere, but even if you do get the engine to run properly with this setup, it will run slower then it did before you vented to atmosphere. You'll be throwing away air that you've worked hard to get into the system. With that said, venting to the air, sounds cool as hell! :smile:
RoadRaceEngineering has them for $320
& BuscherRacing has em for $315
I went with RRE because of good tech-support. I've bought from them before, & I like the way they explained things about the SAFC on the site, & gave me a written diagram (same as 1GDSM) to hook it up. they also have some knowledge on the turbo M/Cs. they are modifying one with a 4G63 I think. BuschRace. only had it listed, with no info, no pic & as far as I know they dont have M/C Turbo knowledge iether. Oh yeah, other places wanted as much as $425 for the SAFC! yikes! :eek:
-vic
I'd rather have it & not need it, then need it & not have it.
