It is currently Mon Jun 03, 2024 4:12 pm
as I understand it, the 1G & 2G 4G63 motor is almost the same. so why havent I heard anyone use the 2GT exhaust cam? if it cant be used, why not? just curious. :grin:
-vic
I'd rather have it & not need it, then need it & not have it.
You can use the 2G exhaust cam. Specs in the manual are similiar to the 1G exhaust cam, not exactly the same. I have both here, I will spec them out (along with some others) one day this winter... it's on that list of things to get done somewhere along the line!
help me understand this,
1g is from 90- 94, or 90-91
and
2g is 95-99, or 92-94??
im a little confused.
i found a few guys nearby with extra ex cams, but they are 92 talon turbo cams, will they work the same?!?!?!?
From all I've gathered, the 89-mid/91 cams have slightly higher lift lobes than the 4G61-T. The post/mid/91-94 are best to use because the lobes have higher lift than the previous (these have a C-stamp at the end of the cam, /tranny side). The 95-99s are better than the 89-mid/91s, are similar to the post/mid/91-94 (but are not known if they are better than them, /yet). All years above are from DSM Turbo manual trans. (if I left anything out, or I am mistaken, please let me know)
I just ordered a Ex-cam from M&S for $75+s&h (mitsu graveyard had it for $40 but only 89-mid/91s)
-vic
OFF SUB///
Drcolt2000; 1G DSM in general, refers to the 89-94 DSM, & 2G to the 95-99 DSM. The hide-away headlamps body design was for 89-91, & in 92-94, mostly the front & rear went thru a change, replacing the hide-aways with fixed headlight assemblies. In 95 the whole car was changed, & in 97-99 the front bumper (along with minor changes), & a diffrent rear wing came out.
Just for fun, the engineers at the Diamond-Star-Motors plant in Normal, IL. decided we DSMers needed a challange, a jig saw if you will, so they mixed & matched different parts here & there, everywhere they saw a nitch, even in the same production year DSMs :smile: & just to keep things interesting, they like to play gotchya! & change part numbers on us even today! those silly bastards! :smile:
89 mirage turbo (daily)
89 colt GT turbo (engineless)
91 talon awd turbo (trannyless)
92 talon awd turbo (winter)
<font size=-1>[ This Message was edited by: MIRAGEDOHCTURBO on 2001-11-20 03:47 ]</font>
