http://4g61t.org/forum/
1993 Mirage 1.8 transmission bolt to a 4g63T Engine ??? ASAP
http://4g61t.org/forum/viewtopic.php?f=6&t=8771
Page 1 of 1
Author:  coltgtman [ Tue May 04, 2004 10:51 am ]
Post subject:  1993 Mirage 1.8 transmission bolt to a 4g63T Engine ??? ASAP
COME ON COLT JUNKIES LOL I NEED TO KNOW ASSAP.
THANKS
Author:  lethalracer [ Tue May 04, 2004 11:33 am ]
no
Author:  mysteryman [ Tue May 04, 2004 12:11 pm ]
What is the transmission code?
Km????
Author:  mysteryman [ Tue May 04, 2004 2:26 pm ]
If it is a F5M22 tranny then it will work, just going to need to get the right flywheel combo.
Here is the gearing info which is taller then the 2.0L DOHC turbo tranny.
1st 3.363
2nd 1.947
3rd 1.285
4th .939
5th .756
4.332 final drive gear
Author:  xlr8 [ Wed May 05, 2004 3:06 am ]
My understanding is that it should have a F5M22 trans in which case there is no problem.
Author:  OGP [ Wed May 05, 2004 6:12 pm ]
Yes it will already done that swap, you will need a Non Turbo 6 bolt flywheel to fit in the tranny, if you plan on putting some power down I would suggest a ACT clucth as well.
Author:  boostfreak [ Thu May 06, 2004 12:13 pm ]
Yes it will work. Hell Im running a 4 speed in my pig!
Gearing is retarted, and will be sweet at the track
https://www.phpbb.com/
