It is currently Mon Nov 03, 2025 6:49 pm
PostPosted: Sat Apr 24, 2004 9:43 pm
I just want to know the differences in them.
Bore x stroke etc etc
PostPosted: Sun Apr 25, 2004 7:48 pm
sorry i dotn have an exact number for you but the stroke is about 10mm les and the bore is about 3mm from memory.
 Post subject: I was told
PostPosted: Sun Apr 25, 2004 7:54 pm
I was told that they are the same but for bore size is that true?
That the rods and crank and all that stuff is the same.
PostPosted: Sun Apr 25, 2004 8:07 pm
The rods are the same the crank is different...
PostPosted: Sun Apr 25, 2004 8:18 pm
no they definatly have a shorter stroke. im sure is 10mm but might be a little either side. they have a different crank but they may have the same rod im not sure, they can do that using a different crank and different pistons im told. the stroke is the reason that the 1600 revs so hard.
PostPosted: Sun Apr 25, 2004 10:00 pm
Banned for being a dick
http://www.4g61t.com/forum/viewtopic.php?t=99&por=1%22
Liink to 4G61T specifications
4G61T 81MM bore 75.5MM stroke
4G63T 85MM bore 88MM stroke
1.6DOHC revs fast for three reasons:
1)short stroke
2)small size bore
3)no balance shafts
Yes the two motors share the same connecting rod.
