It is currently Tue Oct 28, 2025 5:20 pm
 Post subject: 4g63(T)
PostPosted: Tue Nov 18, 2003 7:15 pm
There is a 4g63T engine at a junk yard ~ 5 minutes from my Apt. I talked to the owner and he said he would let it go for $250. Here's the problem, no mani/turbo, unknown miles, unknown condition. Is it worth the $250, it probably needs a rebuild, if I got it I would rebuild it just cause of the unknown condition of the motor. Buy it or skip it?
like my runon sentence? :twisted:
01 Maxima VQ30DE
92 Summit 4g63t (Traded to Evo... R.I.P.)
I heard they ride mooses to work instead of driving cars. (About Canadians.)
PostPosted: Tue Nov 18, 2003 7:23 pm
If you got the time and tools to pull it, go for it. 50% chance its good. Just use your jugement while pulling it out. ie. cracks, holes, broken pieces and rat's nests.
89 colt 4g61t swap (under further construction)
92 talon awd (for sale/needs motor)
PostPosted: Tue Nov 18, 2003 7:32 pm
is it for the motor and tranny or just the bottom and top end of the motor?
PostPosted: Tue Nov 18, 2003 7:34 pm
Just for reference, we sell good rebuildable long blocks for $450
If it don't make power it's not worth the hour!!!!!
PostPosted: Tue Nov 18, 2003 8:33 pm
top and bottom, nothing else
01 Maxima VQ30DE
PostPosted: Tue Nov 18, 2003 8:45 pm
thats not a bad price, if nothing else you could sell the head for like $150 if you wanted some of your money back if the block is garbage. I bought a junkyard motor before and the crank was worn pretty bad so i'm not using the bottom end, but i got the head, tranny, wiring harness, turbo, etc out of the deal. i'd say check out the motor for internal damage, if it's good then it's not a bad deal for $250
PostPosted: Wed Nov 19, 2003 11:13 am
yep, that is for a perfect crank, no cylinder wear and a good head that needs surfacing, it is a engine that has either been bad ie. less that 130psi compression, excessive blow by, or slightly bent valves. we wouldent sell an engine with a valve stuck in the head.
you would get the complete head,block, timing components, oil pan and front engine mount.
