It is currently Fri Apr 26, 2024 2:51 am
 Post subject: BELLHOUSING
PostPosted: Mon Aug 20, 2018 6:05 pm
Hello guys
I am having a bellhousing made and I am almost 100% positive, but dont want to make a mistake.
The bellhousing will be for a 4g61t to run it rear wheel drive.
Will the bolt pattern on the blocks 4g61t and 4g63t be the same, I am almost sure they are but the bellhousing maker wants me to be sure, especially going, lets say reverse to what everybody else is doing.
Will there be anything specific to the 61 that will make it different from being a bolt on from a 6 bolt 63.
Thanks
arrowhead
 Post subject: Re: BELLHOUSING
PostPosted: Mon Aug 20, 2018 8:16 pm
Its the same. Unless you have a personal connection on having something made, I'd use Bill Hitcher, he does awesome work.
http://www.billsautofab.com/
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Mon Aug 20, 2018 9:09 pm
Thank you Nate
Bill is the man.
So there are no extra holes or dowel pins that would make a difference.?
PostPosted: Tue Aug 21, 2018 6:58 am
Shouldn't be. I mean the 63 bolts right up to the 61 trans. That's my thoughts behind it.
I have one of Bills housings for a t-56. Can't wait to use it!
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed Aug 22, 2018 9:01 pm
Thanks nate
T 56 is what I would go with if I did not have 2 muncies and a T10,.
What is going to be your combo.
I am going with the 61 and leaving it N/A, I have another 61 which will be turbo, and then be able to run another class, this will be going into a 98 Talon.
Mandy
PostPosted: Wed Aug 22, 2018 9:26 pm
I've got an old Magnus 2.3 with a FFWD street dominator 2g head. Plans are to mate it to a t56 and install in a first gen colt... one day...
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
Users browsing this forum: No registered users and 45 guests
