It is currently Thu Mar 28, 2024 6:03 am
 Post subject: Walbro 255 install
PostPosted: Wed Jan 03, 2018 10:54 pm
Ive been looking for a write up or instructions on a fuel pump install but have no luck finding anything solid. Ive seen several posts about a FAQ detailing the install but i cant seem to find it. I know I need to drop the tank but I would like to be as prepared as possible when doing this install. Also doing a rewire. If someone could point me in the right directions...Thanks.
 Post subject: Re: Walbro 255 install
PostPosted: Sun Apr 08, 2018 5:01 pm
http://www.vfaq.com/index-main.html
Should have all your answers under "fuel", just follow the first "1g AWD" install link. Besides you needing to drop your CSM tank it is pretty much exactly the same as a 1g AWD.
As for the rewire follow the very first link in the Fuel Pump Rewires box.
PostPosted: Wed Apr 25, 2018 6:37 pm
It's nearly a direct swap for the stock pump. Only a few tweaks and it'll pop right in.
