It is currently Thu Apr 25, 2024 12:29 pm
PostPosted: Fri Jul 21, 2017 8:31 am
I was wondering if a fwd 1g swap will work in my colt . I know I will need the motor mounts & attachment for wire harness what else will I need / what can I use ? Thanks !
PostPosted: Fri Jul 21, 2017 12:22 pm
Spend 30 seconds reading around this forum.
Yes it will work
PostPosted: Fri Jul 21, 2017 3:22 pm
A donor car will always be your best bet to get all the little parts but you will still need more parts. I'm assuming you have a 1.5 car. Is it manual or auto? If manual, cable clutch or hydro?
in short if you have a 1.5 car you will need a different rear engine mount, timing belt mount and trans mount. You will also need colt specific axles. The 1.5 or dsm axles are not the right ones. You will either need to hardwire the dsm engine harness in, there are a few good write-ups in the archives. Or I've been making plug and play adapters for a while that I sell. I also modify rear engine mounts and trans mounts for the swap. You can buy the timing belt mount new at Rockauto cheap, look for a 94 Hyundai Elantra with the 1.8.
Look in the archive and read up a little, the info is all here. Post back if you get overwhelmed or just can't find what you're looking for and we'll be glad to help.
PostPosted: Fri Jul 21, 2017 9:29 pm
You guys forgot hat he needs to add his location too. :axe:
