It is currently Fri Apr 19, 2024 12:45 pm
 Post subject: Oil pressure guage
PostPosted: Fri Sep 23, 2016 10:34 pm
Im not running an oil guage yet. What can anyone share that has done the swap?
DRCOLT
1989 3g Colt GT turbo w/4g63t
 Post subject: Re: Oil pressure guage
PostPosted: Sat Sep 24, 2016 9:45 am
I would just go aftermarket so you get an actual gauge too. Just be sure to buy the special fitting that allows you to thread the pressure sensor into you filter housing. It converts bspt to npt.
PostPosted: Mon Sep 26, 2016 8:34 am
That is the best ^^^^
I ran GlowShift electronic Oil Pressure, Coolant Temp and Boost (took them into my GVR4 and still run them without issue) Sensor fit without modifications and had plenty of clearance from the cross-member to avoid contact when the motor shifts.
PostPosted: Wed Sep 28, 2016 8:52 pm
Make sure to remotely mount the sender away from the block. 12" or so of 4an line. Vibration kills pressure senders.
PostPosted: Mon Oct 03, 2016 6:26 am
So the factory sender doesn't get used to send a signal to an aftermarket gauge?
DRCOLT
PostPosted: Mon Oct 03, 2016 11:12 pm
The oil pressure gauge should come with sending unit. Also I found out a few weeks ago that the port you will use is not NPT it is 1/8" BSPT so you would need an adapter or to retap it 1/8" NPT.
