It is currently Fri Mar 29, 2024 8:07 am
PostPosted: Wed Jul 13, 2016 4:20 pm
Im having problems with my 4g61 no power to injectors and no spark fuel pump is running when cranking ive changed the ecu and mpi relay still no luck there's power going to the ecu but nothing to injectors or coil when i turn on ignition engine check light doesent come on at all any ideas
PostPosted: Thu Jul 14, 2016 4:09 am
Change, or look for the wires of the crank angle sensor (this is in the left side of the cylinder head, connected to the camshaft)
Daily: '91 Nissan Micra 1.2 SuperS Suntop
Weekend: '95 Mitsubishi Colt 4G63T (EVOII) FWD, LSD, full stock
Project: '89 Mitsubishi Mirage Turbo 4G61T, now full stock,
PostPosted: Thu Jul 14, 2016 1:02 pm
I have looked at that there is no power coming to that either car was running switched it off and refused to start again thats how i discovered the problem with spark and injectors no fuses gone no sign of broken wires when i crank the engine the coil gets power for a split second but then nothing its baffled me
PostPosted: Thu Jul 14, 2016 5:04 pm
If the check engine light doesn't come on then it's ECU related. Maybe you tried a second bad ecu?
PostPosted: Thu Jul 14, 2016 6:14 pm
It was running when i replaced the ecu it was a recon thats why i cant figure it out i turned it offf and it wouldnt start again its a weird one if i open up the mpi relay and press the contact the engine light comes on but stays on
