It is currently Fri Apr 26, 2024 10:41 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
 Post subject: Re: Built 4g67/G4CN
PostPosted: Fri Oct 07, 2016 9:35 pm
Have you thought about doing an actual compression test on this engine to see if it's higher/lower than stock or that of a 4g63t? It won't tell you your exact CR but it will tell you something.
I did the math using this calculator:
http://www.csgnetwork.com/compcalc.html
According to my numbers I got 8.0:1 to 8.1:1 CR on the 4g67, which is not bad for boost and considering the abuse that has been getting at @25+psi it seems to be accurate...
