It is currently Sat Apr 27, 2024 7:02 pm
PostPosted: Sun Sep 06, 2015 5:01 pm
I really need a picture of the large plug going into the ecu both top and bottom. I have thoroughly fruit and banana mine over and Mitsubishi didn't do me any favors with duplicate wire colors. Not to mention these wires are really degrading in color after 25 years.
I really need a pic of the backside where the wires enter the clip both top and bottom I believe it's inputs 1-24. Thank you in advance, I am about ready to drive this car off a cliff.
PostPosted: Mon Sep 07, 2015 4:04 pm
Hang on a few minutes....I'm working on that for you.
Good stuff - trucks bring it!
PostPosted: Mon Sep 07, 2015 4:28 pm
This is for an 89 Colt turbo like yours.
A couple pictures for reference, but I went ahead to list every single wire going to the plug just below. You MUST look in the manuals to see if I am giving you the correct numbered pins. In other words, if pins 1 thru 24 are correctly positioned.
Plug facing you *Top left starts number one pin, bottom right ends in 24*
1 Yellow wire, Red Stripe, Red dot
2 Blank
3 Green wire, Blue Stripe, Red dot
4 Biege
5 Green wire, Orange Stripe, Red dot
6 Green wire, Yellow Stripe
7 Black wire, Red dot
8 Blue wire, White Stripe
9 White wire, Red dot
10 Blue wire, Black Stripe
11 White wire
12 Yellow
13 Green wire, Black Stripe
14 Green wire, Red Stripe
15 White wire, Red Stripe
16 Black wire, Red dot
17 Yellow wire, Green Stripe
18 Green wire, White Stripe, Red dot
19 Yellow
20 Blank
21 Green wire, Yellow Stripe, Red dot
22 Blank
23 Blue wire, Red dot
24 Black wire, Red Stripe, Red Dot
PostPosted: Wed Sep 30, 2015 11:59 am
I owe you one. Sorry about the delayed response.
