It is currently Sat Apr 27, 2024 3:19 am
PostPosted: Tue Dec 02, 2014 7:23 pm
Anyone know if the stock 4g61t flywheel bolts are the same size as the 4g63t? I will be installing a DSM fwd flywheel/clutch onto the swapped Colt GT but not sure if I'll need to order new bolts as well. Anyone reuse their old bolts on a dsm flywheel?
DSM's are part #MD040557 and I believe 12x22.5mm
PostPosted: Tue Dec 02, 2014 10:23 pm
Sent you a message.
Stock 6 bolt flywheel bolts should all be the same.
Using an aluminium flywheel means needing longer bolts due to mating surface thickness increasing.
Toyota ARP 12 point flywheel bolts are what I used from memory. I don't have the part #'s handy just yet however.
Here's a reference to longer OEM Mitsubishi flywheel bolts.
Click me for longer bolt kit
