head bolt torque spec? http://4g61t.org/forum/viewtopic.php?f=6&t=39107 |
Page 2 of 2 |
Author: | ben4g63t1 [ Sun Sep 07, 2014 7:51 pm ] |
Post subject: | Re: head bolt torque spec? |
hmm, maybe. I ended up just cleaning the threads up and cleaned up the mounting surfaces and popped it back on/torqued them down...everything felt good. The piston in the number 1 cylinder looked a little damaged, and the head had 2 different looking valves compared to the rest...interesting finds. Either way if i take the head off again in the near future i'll just get some new bolts or studs and exchange the gasket for a new one since its got a 1 yr warranty. Sux to do things twice, but if i have to do it, then thats what i'll do. Thanks for all the help and info, much appreciated. as soon as its back in time and i get it running i'll keep u all posted/updated. Good to know flying eagle...i actually left the intake manifold on, but if i get the cash i may remove it to replace it if the gaskets i change around the throttle body and egr valve dont solve the problem of hard starting/only runs on starting fluid. Ben |
Page 2 of 2 | All times are UTC-05:00 |
