shim new clutch fork? http://4g61t.org/forum/viewtopic.php?f=6&t=38828 |
Author: | king_of_the_street [ Mon May 19, 2014 8:38 pm ] |
Post subject: | shim new clutch fork? |
Hopefully changing the Pressure plate solves my problem, but Ok, so I'm waiting on my act2600 to arrive this Wed. I have the comp ball and fork. The ball came with plastic washer so I changed that with the metal one I had from the previous ball. The question I have is do I need to shim the new ball more than just one washer with the act2600? |
Author: | Mechacode [ Tue May 20, 2014 4:26 am ] |
Post subject: | Re: shim new clutch fork? |
The general rule is one (hardened) washer at most. |
Author: | xxNocturnalxx [ Tue May 20, 2014 7:18 am ] |
I've never used any washers unless included, so I'm sure just one is fine. |
Author: | slowdsm [ Tue May 20, 2014 1:12 pm ] |
Quote: The general rule is one (hardened) washer at most.
100% accurate... make sure its hardened and ONLY use 1.. I used 2 once and the ball stripped out and fell out.. had to permanently weld it in.. it sucked. Steve |
Author: | king_of_the_street [ Wed May 21, 2014 9:07 am ] |
wow that must sucked, but thanks thats what thought, i was just reading some things about heavy duty pp, probally just misread. better to do right first time Im taking a shot a new pp will fix my problem just trying cover all aspects correctly so no doubts in my mind |
