It is currently Sat Apr 27, 2024 3:51 pm
PostPosted: Sat Mar 15, 2014 3:57 pm
Hey.
Does anybody know what should be stamped on OEM rod bearings, 4g63T?
I'm replacing them and usually they had "STD" markings on them (N/A ones), but this one doesn't.
I just want to be sure that no one before already cut the crankshaft..
Any input on this will be helpful.
Thank you.
PostPosted: Sat Mar 15, 2014 7:56 pm
I'm not sure but can't you just measure the journal and compare it to the specs in the FSM?
PostPosted: Sun Mar 16, 2014 5:11 am
The easy way to know if the clearance are ok is a plastic gauge test.
Look here : Google shearch
Also a good thread : look below
