It is currently Sat Apr 27, 2024 3:09 pm
Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
 Post subject: Re: 4G61 vs 2g heads
PostPosted: Wed Sep 04, 2013 10:10 pm
Jerry's ( lancerman ) insane post from back in the day. Insane is meant to instill confidence. 8)
http://www.4g61t.org/forum/viewtopic.ph ... or&start=1
PostPosted: Mon Sep 09, 2013 11:40 pm
DSMTuners thread where you can see CC from 1G heads with oversize and 6T stock valves installed with various deck heights.
http://www.dsmtuners.com/forums/dsm-bui ... -bolt.html
PostPosted: Tue Oct 15, 2013 12:57 pm
I'm about to use a 1.8l head on a 2.0l block in my 1990 Eagle Talon awd turbo...
If it's of intrest or you have any thing to add I'm all ears.....
Go here:
http://www.4g61t.org/forum/viewtopic.php?f=22&t=38192
PostPosted: Fri Nov 29, 2013 9:59 pm
Go for it!
Tiny bump in compression won't mean a thing. Tuning still has to be performed anyway. It was an issue in the old days with 9.5:1 and running the JDM AWD code that bumped timing up really fast and kept it fairly high, on 91+ octane gas. The Japanese had better fuel and well, wasn't an issue for them. If the motor was out of tune, made for lots of knock once upon a time. Now you have self-tuning programs, SwedeDensity .... and Speed Density/Map systems running into the management of older engines. Good times if you ask me!
