http://4g61t.org/forum/
arp head bolt problem
http://4g61t.org/forum/viewtopic.php?f=6&t=3661
Page 1 of 1
Author:  midnight [ Wed Apr 16, 2003 9:16 pm ]
Post subject:  arp head bolt problem
i went to put my headstuds in. and they are way too loose i realy dont think they are going to tq down. whats the deal?
i am using 4g63t studs, and its a 4g61t if that helps
Author:  adamrx7 [ Wed Apr 16, 2003 11:22 pm ]
Thats a anew one on me, I have never ran in to that problem with ARP studs.
Author:  adamrx7 [ Wed Apr 16, 2003 11:31 pm ]
Are the 1st gen studs or 2nd gen?
Author:  BlueBullet [ Thu Apr 17, 2003 2:28 pm ]
Im using head studs in my motor right now...I got the ARP stud p/n 207-4701. They are about $30 more expensive than the regular head stud kit from them (-4201). The kit is a 89-94 4G63 12mm uncut head. If you compare the regular ARP stud kit to the uncut one, it not only has a little more threading, but the threads are not cut into the stud..they are rolled, meaning they are stronger (they dont make the stud, and then cut material out to make the thread).
I consulted Bill over at Holeshot about it, and he said the headstuds were kinda overkill, but the block could hold 40+lbs of boost if needed (i only found out about it after i purchased the kit). Cant complain, and I know the stock bolts will hold down up to 20psi, but Im anal retentive about my motor...I love new stuff neways hehe.
https://www.phpbb.com/
