| 1.7L 4g61t http://4g61t.org/forum/viewtopic.php?f=6&t=36390 |
| Author: | Frankencolt [ Fri May 04, 2012 8:00 pm ] |
| Post subject: | 1.7L 4g61t |
I have an old 4g61t block lying around that I've been trying to put back together, but I don't have the stock pistons. I was wondering if these pistons would work? (with boring of course) http://www.built4g63.com/Wossner-8-1-2. ... n-Kit.html I figure it should work with the stock length rods, since the stroke difference between the 63 and 64 is 12 mm and between the 61 and 63 is 13mm... Any thoughts? |
| Author: | ColtiXim [ Sat May 05, 2012 1:39 am ] |
| Post subject: | Re: 1.7L 4g61t |
Good infos here: http://www.4g61t.org/forum/viewtopic.ph ... g63+piston http://www.4g61t.org/forum/viewtopic.ph ... g63+piston http://www.4g61t.org/forum/viewtopic.ph ... g63+piston |
| Author: | Frankencolt [ Sat May 05, 2012 2:27 am ] |
So, really I could use stock 63 pistons, I'd just have to shave .5mm off the top? |
