| throttle closed switch wiring help! http://4g61t.org/forum/viewtopic.php?f=6&t=36356 |
| Author: | king_of_the_street [ Sat Apr 28, 2012 9:55 pm ] |
| Post subject: | throttle closed switch wiring help! |
where does the wiring for the 1g throttle closed switch wiring go? is it just a ground? My wiring for that on my 1990 harness is not there.. thanks |
| Author: | slowdsm [ Sat Apr 28, 2012 11:13 pm ] |
| Post subject: | Re: throttle closed switch wiring help! |
u have a pic? most people think the adjustable connector on the back side with a single wire is that..but its the ac idle switch. a pic would help determine if its that or not. Steve |
| Author: | king_of_the_street [ Sun Apr 29, 2012 12:02 am ] |
I'll take pics asap and yes it's the single wire tab, that let's ecu know when throttle plate is closed.. The wiring is missing, trying to see how to wire it in.. |
| Author: | Flying Eagle [ Sun Apr 29, 2012 8:24 am ] |
Check the manuals listed at http://www.lilevo.com/mirage/ That switch wire will go right back to the ECU harness plug-ins. 8-35 in the 90-91 Talon Electrical manual. B-05 is the connector, the wires have to be in that harness section somewhere leading back to the firewall. It would be pointless and backwards to remove that wire. Worst case, you can run a new wire with rubber boot, all the way back in for the ECU. Pin 6 on the 90 ECU/harness. |
| Author: | king_of_the_street [ Sun Apr 29, 2012 11:05 am ] |
thanks alot! |
| Author: | king_of_the_street [ Sun Apr 29, 2012 10:04 pm ] |
Hey thanks again! I forgot im using a 90 harness converted to a 91... & my motor is a 91... I forgot when i wired in the tps connector I left that green wire alone in the shrink wrap |
| Author: | Flying Eagle [ Sun Apr 29, 2012 10:37 pm ] |
Glad to hear it jogged your memory. I was very thankful to have had a turbo car to start with and enough parts to make a 90 version of the 4g63t motor I installed. |
