| Check valves for high boost? http://4g61t.org/forum/viewtopic.php?f=6&t=36088 |
| Author: | pyro719 [ Wed Feb 29, 2012 11:02 pm ] |
| Post subject: | Check valves for high boost? |
So I rebuilt my throttle body with new shaft seals and I can hear air in the valve cover. Can I put a check valve in my pcv line and my brake booster line? Im going to be maxing this 16g out so I need to hold 30psi or so. All the auto parts stores dont sell the right size check valves. What are you guys doing to hold high boost? |
| Author: | biglady112 [ Thu Mar 01, 2012 1:18 pm ] |
| Post subject: | Re: Check valves for high boost? |
That little engine likely has blowby. Did you try to turn the motor to top dead center and do your test? We boost leak tested mine last week and had to play with it a little to get all the valves closed. I still had air in the crankcase, but it stopped coming out my exhaust. You stock brake booster line should have a check valve in it from the factory. I would not worry too much. You can always to a scavenging catch can and that will help. I highly recommend that anyway. |
| Author: | pyro719 [ Thu Mar 01, 2012 2:44 pm ] |
I believe the pcv valve is leaking. With the oil cap on mad air comes out of the breather line. I ordered a few check valves from us plastics they are supposed to be good to 150psi. I just want to make sure im ot leaking boost into the brake booster and valve cover. I think the check vaves are the ticket |
| Author: | biglady112 [ Sun Mar 04, 2012 9:21 am ] |
Keeping that pressure in the motor is a bad thing. You want it out. A vacuum pump or scavenging system is the best approach here. |
| Author: | pyro719 [ Sun Mar 04, 2012 10:48 am ] |
Ive still got the factory intake that sucks air from the valvecover. I think ill be fine |
| Author: | biglady112 [ Sun Mar 04, 2012 11:08 am ] |
That is just one hole and it is literally like trying to breathe through a straw. |
| Author: | pyro719 [ Sun Mar 04, 2012 12:32 pm ] |
I may add a catch can and increase the breather line size. Ill have to see how it looks when I get this 16g to boost more than 10 psi. My check vlaves will be here Tuesday. |
| Author: | biglady112 [ Sun Mar 04, 2012 12:48 pm ] |
It really needs to be a sealed catch can with a return to the intake. This is the only way to be effective and draw the pressure out correctly. |
| Author: | xxNocturnalxx [ Sat Mar 31, 2012 4:26 am ] |
How did the check valve work for you? I will be running one inline with the pcv valve, I am having some excess vc pressure as well due to a failing pcv and I believe this will do the trick. |
| Author: | xxNocturnalxx [ Sat Mar 31, 2012 5:23 am ] |
For search and info purposes here is good check valve used by DSMers. http://www.rtmracing.com/xcart/product. ... t=0&page=1 |
| Author: | pyro719 [ Sat Mar 31, 2012 9:43 am ] |
The check valves worked good! |
| Author: | TenSecondSTi [ Fri Apr 27, 2012 11:13 am ] |
just add some ventilation to the valve cover. By ether drilling taping in barbed fittings or have some -10an fittings welded to it. |
