It is currently Mon Nov 03, 2025 4:01 am
PostPosted: Sat Nov 05, 2011 7:26 pm
i have a 1988 misti with a fwd 4g61t engine in it, butmy problem is im running on 3 cylinders, spark plugs are fine, injectors are fine, compression was fine so i thought it might have been the spark, which it was so i replaced the coils, but sill have the same problem, its getting voltage but not enough, iv replaced the lead to, does anyone know what else it could be?
thanks, eveyone has been helpfull on this site!
PostPosted: Sat Nov 05, 2011 10:23 pm
What are testing for voltage with? So, 1 cylinder went down - but the plug was not saturated in fuel? Swap a new plug in to start, if spark checks out fine.
