First i did wideband cause i wanted to see what was happening. It has symptoms of weak fuel pump. It seems to lean out right when it starts to miss at mid-load. (10 psi at 1/4 throttle or 5 psi at full, an it all varies on rpm.) I also have replaced the pump, with another walbro i have a spare. replace the fuel pressure regulator (i have two full cars worth of spare parts) fuel filter, and checked the wiring at the pump. I really dont think its the pump, but it acts this way. I replaced the injectors, spark plugs, wires, coils.
I also installed the aem ems back in so i could log it and just see how it acts with it, It does the same thing. Misses at mid load.
The only thing i know i can do that will work for sure is to just take the turbo off. It runs fantastic anything under 150 hp.
When it misses its like its running on 2 cylinders Its either losing two or firing all four half the time.
There is no check engine light. I dont have a code reader anymore, but the cel does work for sure
