It is currently Sun Apr 28, 2024 12:31 pm
 Post subject: vacuum check valve
PostPosted: Thu Aug 04, 2011 3:43 pm
what are you guys using if anything to block boost from getting into the brake booster?
i have yet to find a suitable check valve for 3/8ths hose.
 Post subject: Re: vacuum check valve
PostPosted: Fri Aug 05, 2011 10:08 pm
I don't know of many people adding it, but I could be very wrong.
Not many posts about this one, but I remember a discussion some time back.
Any brake booster hose with a valve from a turbo DSM/GVR4/VR4 of similar vintage should be the same thing.
PostPosted: Fri Aug 05, 2011 10:40 pm
From what ive seen, these hoses have a white plastic tube in the middle of the hose but it isnt a valve, more like a t~fitting. The boosters temselves have a check valve but I'm on an elantra booster now and who knows if they really seal, I don't need to blow the diaphragm on a run or be knocking from a hidden boost leak.
PostPosted: Wed Aug 17, 2011 12:30 am
i put one on my car from an acura integra just because its what i had on hand... i was geting a funny humming noise from my booster when boost leak testing at anything over 10psi
PostPosted: Thu Aug 25, 2011 12:58 pm
i ended up buying a check valve from a supra. i got it from a yota dealership as you cant get them from az or other parts stores looks like:
i actually popped my booster diaphragm two days ago when i spiked 30psi, got this today and im about to try it out, the part number is:
44730-2402
it runs as much as 50$ from the stealership but its a tough lil piece and its not worth it having a 20yr old internal valve blow up during a run when you might need your brakes right quick.
also my elantra booster came with NO internal check valve and on the older colt gt booster i had, the valve was sticky and didnt work quickly causing an intermittent boost leak and often no power assist after a few gears of WOT. sofor the guys who dont already have good brakes or looking to upgrade to the elantra stuff, id just add this part or something similar to your list.
also i tried a dsm pcv valve for awhille, it didnt work, just fyi.
PostPosted: Thu Aug 25, 2011 8:45 pm
Great find and post!
PostPosted: Fri Sep 02, 2011 12:09 pm
That is not only a boost leak-but it will hinder the performance of your booster.
Same issue 6Bolt is/was having
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Mon Aug 18, 2014 9:14 pm
http://www.amayama.com/search/?q=MB277029
That part # is a C53a cyborg brake booster valve.
MB277029
Likely the same part for all the turbo cars with that size hose from the brake booster to the intake manifolds.
PostPosted: Wed Aug 20, 2014 7:43 am
The best valves you can buy for these applications are the US plastics check valves. I always run these as even new OEM ones leak. Simply run this inline. brake booster, PCV, catch cans ect. http://www.usplastic.com/catalog/item.aspx?itemid=23369
PostPosted: Wed Aug 20, 2014 5:48 pm
Hey, nice find there.
Great to see specs on the parts also.
Users browsing this forum: Bing [Bot] and 47 guests
