http://4g61t.org/forum/
Blowing gearboxes..
http://4g61t.org/forum/viewtopic.php?f=6&t=34827
Page 1 of 2
Author:  slyborg [ Thu May 26, 2011 6:13 pm ]
Post subject:  Blowing gearboxes..
Just wanted to put up a quick thread asking if any body else has trouble with 4g61t gearboxes? Is it a common problem for them to blow, i've been through two in under two months? :(
Author:  89Mirageman [ Thu May 26, 2011 6:18 pm ]
Post subject:  Re: Blowing gearboxes..
Stock engine?
Author:  Incoltnito [ Thu May 26, 2011 6:19 pm ]
The stock transmission mated to a 4g61t motor is the KM210 tranny. Are you at or around stock power level, and under what condition did the transmissions go out on you?
Author:  CaptainTonus [ Thu May 26, 2011 6:35 pm ]
Short answer: yes
Author:  j2dapo [ Thu May 26, 2011 7:17 pm ]
Weren't some 1.6L engine in other markets (Asia/JDM) matted to KM206 tranny's? I ran a sonata km210 last year on a 2L with a gt30 turbo, never had any issues, but I never launched the car either.
Author:  twokss [ Thu May 26, 2011 8:37 pm ]
I grenaded a shep rebuilt km210. It was neato
Author:  Natedog [ Thu May 26, 2011 8:50 pm ]
I've only broken the 3rd gear shift fork on mine, and I've beat the shit out of it...not sure what you guys are doing :)
Author:  Johnny_B. [ Thu May 26, 2011 10:27 pm ]
I generally just blow Trannys.
Author:  Legolas337 [ Fri May 27, 2011 7:52 am ]
Remind me what corner your picking them up at so I dont have that problem too. Should be the other way around! :lol:
Author:  CSM Shaun [ Fri May 27, 2011 8:50 am ]
My Summit LX sedan has a KM206 in it.
Author:  moidsm1 [ Tue May 31, 2011 12:45 pm ]
Yea. recieving a blow is borderline ok, especially if you didnt know, but knowingly blowing trannies is very homosexual
Author:  slyborg [ Sun Jun 05, 2011 6:19 pm ]
I am around stock power, maybe slightly higher, I have raised the boost pressure slightly but that is about it, ive blown two of them in under 4months. i live in newzealand so it is a jap import? maybe slightly different to the mirages you guys get over in the states? maybe its just my driving style?
Author:  Incoltnito [ Sun Jun 05, 2011 7:30 pm ]
Are you blowing up the gears or the differential? Also, what kind of gear oil are you using? Maybe it's just bad luck, but it could also be driving style. I would assume if you are around stock power level then it's not driving style related. The only time I blew a transmission was when a dowel pin flew out of the flywheel, which was due to rust working it out under normal driving. I also lost a 4-speed that went by natural causes on a 200,000+ mile motor.
Author:  slyborg [ Wed Jun 08, 2011 11:33 pm ]
Im hoping it's only badluck because i have just put in the 3rd gearbox.
The first gearbox it was 2nd gear, second one was the diff
Author:  j2dapo [ Fri Jun 10, 2011 1:05 am ]
the km210 should say km210 on the bottom.
Page 1 of 2 All times are UTC-05:00
https://www.phpbb.com/
