http://4g61t.org/forum/
Getting my stock tach to work... (92 eagle summit 4g63t)
http://4g61t.org/forum/viewtopic.php?f=6&t=32868
Page 1 of 1
Author:  93'TSIColt [ Wed Jun 16, 2010 11:22 pm ]
Post subject:  Getting my stock tach to work... (92 eagle summit 4g63t)
This applies to my 4g63t swapped 1992 Eagle Summit wagon/van.
It originally had the 4g64 sohc engine installed. Came with a tach from factory on the cluster. The 4g64 uses a internal coil inside the distributer and gets it's tach signal from there? I would like to get the tach to work like it should from factory. Wondering if this is even possible.
anyways i tried to run my tach signal to the proper wire for the stock intrument cluster for the tach but i get nothing.
Tach just sits at 0... al the time.
Is there any way to get the tach to work? (2.4L sohc tach with the 4g63 DOHC DIS engine.)
Author:  Mechacode [ Thu Jun 17, 2010 3:38 pm ]
Post subject:  Re: Getting my stock tach to work... (92 eagle summit 4g63t)
I think you'll need a tach filter wired in to combine the two separate coil signals into one for the gauges to read.
Author:  89Mirageman [ Thu Jun 17, 2010 4:10 pm ]
Thats what I would do, grab a 90 dsm tach filter (all 92-95 hyundai elantra's use them too) and wire it to your current coil pack. Then take the extra wire and run it to the tach wire in the dash.
Author:  93'TSIColt [ Fri Jun 18, 2010 2:32 am ]
okay thanks guys, ill try this! i have lots of 1990 dsm coils sitting around. What part of the coil is the filter exactly???
Author:  89Mirageman [ Fri Jun 18, 2010 9:32 am ]
If you compare one to a 91+ coil pack it will be obvious. It mounts on with two small screws and a few of the wires go to the coils, then there is a third wire that goes to the four wire plug, white wire I think. This is the one that you tap into your dash/cluster.
Author:  93'TSIColt [ Sat Jun 19, 2010 1:41 am ]
okay ill try it out and let you guys know how it goes.
Author:  grndsm [ Thu Oct 13, 2011 8:59 am ]
Did this work? I am facing the same problem on '93 Summit Wagon.
I know that I could install a DSM tach, but I am trying to see if there are any better options.
Author:  93'TSIColt [ Thu Oct 13, 2011 11:49 am ]
sold the car before i could change it around.
https://www.phpbb.com/
