| Crank/Pistons In: Need Torque Specs. http://4g61t.org/forum/viewtopic.php?f=6&t=3248 |
| Author: | Bill Spruill [ Fri Mar 07, 2003 4:48 pm ] |
| Post subject: | Crank/Pistons In: Need Torque Specs. |
| Author: | 2.0pwrdc50 [ Fri Mar 07, 2003 6:41 pm ] |
| Post subject: | |
connecting rod cap:36-38ft.lbs. bearing cap:47-51ft.lbs. not sure if this helps, got it from the 89 service manual vol.1 gary |
| Author: | Bill Spruill [ Fri Mar 07, 2003 6:56 pm ] |
| Post subject: | |
| Author: | 2.0pwrdc50 [ Fri Mar 07, 2003 11:23 pm ] |
| Post subject: | |
| Author: | Crackerman [ Sun Mar 09, 2003 3:28 pm ] |
| Post subject: | |
are you using stock fasteners or A.R.P. studs and bolts? for the factory fasteners, the above torques specs are correct If you are using A.R.P. products(which i would HIGHLY recommend) its 40lb, break loose and trque to 40 3 ties for the rod bolts with the moly lube supplied, and for the main studs its 60 with moly lube, head studs are 80 with moly lube, torqued in 3-4 stages of course. www.summitracing.com is a good supplier of them, as they cost about 50% or less than rre's or extreme motor sports cost. |
| Author: | Bill Spruill [ Sun Mar 09, 2003 5:49 pm ] |
| Post subject: | |
Thanks, Crackerman. I already torqued con. rods to 38 and mains to 51, as by Gary (2.0powerc50), above. I am using ARP's and the molylube. So, I guess I should release that and continue for two more times at 40 con. and 60 on mains. We can get that Mon. Have been waiting for a gasket for the oil pump before closing, so nothing lost. Hope to get the head on Mon. or Tues. (Torqued to 80 three times with molylube as you suggest. And Yes, they did come from Summitt with free shipping. Bill Spruill, oldest Colt |
| Author: | Crackerman [ Mon Mar 10, 2003 9:11 pm ] |
| Post subject: | |
torqued to 80, 3 times? no, in 3 or 4 stages, like 20, 40, 60 and tehn 80, then 80 again, usually you only need to do it once, and if you really wanna make sure that its good, you can then retorque to 80 after the engine is warm, but is not necessary, |
| Author: | Bill Spruill [ Mon Mar 10, 2003 9:48 pm ] |
| Post subject: | |
Got it. Held up today, so nothing lost. Thanks. Bill Spruill, oldest Colt |
| Author: | 2.0pwrdc50 [ Mon Mar 10, 2003 11:18 pm ] |
| Post subject: | |
sorry bill, forgot to ask those questions first.. |
| Author: | Bill Spruill [ Tue Mar 11, 2003 6:09 am ] |
| Post subject: | |
Not to worry. It makes a good thread for future use, and, like I said, nothing lost. |
