It is currently Sun Oct 26, 2025 7:16 pm
 Post subject: block help
PostPosted: Tue Mar 04, 2003 1:09 pm
Is the 4g61t block the same as the 4g61 block with just different pistons. if so i can go pic up two 4g61 block for penneys.
PostPosted: Tue Mar 04, 2003 2:13 pm
BANNED FOR FRAUD
The bare blocks should be the same.
Jason Veraldi
Scammer
 Post subject: squirters?
PostPosted: Tue Mar 04, 2003 2:26 pm
The 4g61t block might have squirters for the rods? This is the only difference between the 4g63 and 63t. Also check to make sure there is a knock sensor tapped hole on the non-t.
Chris
PostPosted: Wed Mar 05, 2003 1:13 am
CAPS shows the the 61t block has the squirters. so it might be safe to assume the 61, 61t diffrences are the same as the 63, 63t block in the forged dept.
 Post subject: Re: block help
PostPosted: Wed Mar 05, 2003 2:17 pm
I HAVE a good 4G61t core block/crank/and rods..... 200.00.....
If I put it together it'll cost you 450.00 for a fully built stock bottom end...
Geoff
Mach V
