It is currently Sun Oct 26, 2025 11:42 pm
 Post subject: wont boost at all
PostPosted: Tue Aug 21, 2007 10:05 pm
hi guys ,
i reinstalled my 4g63t on my c-10 again, after many problems i got it together, adjusted idle speed, ajusted timming, and ready to go, but !!!!! when i drive the car i noticed thet the eng wont advance, RPM goes high when i step in the gas pedal , but the car wont move its like iam driving with the parking brake on,,
so far no intake leaks, good fuel delivery, right timing,,,,,,, this swap is becoming a pain in my ass..
anny suggestion?? thanks
PostPosted: Tue Aug 21, 2007 10:33 pm
by the way my EGR valve its been remove and all the ports at the TB had been plugged
PostPosted: Tue Aug 21, 2007 11:38 pm
Bad clutch? If your clutch was bad, you wouldnt boost due to not placing a load on the engine. This would explain your engine revving, but not going anywhere and not boosting.
PostPosted: Wed Aug 22, 2007 12:51 am
wastegate connected properly?
PostPosted: Wed Aug 22, 2007 6:53 am
the waste gate is installed properly but is this can be the problem? that the waste gate is no closing at all
PostPosted: Wed Aug 22, 2007 7:01 am
or just bad gate. think that is what just happen to my stock mirage. wow are these 1.6 slow without turbo.
