http://4g61t.org/forum/
starting with no gearbox?
http://4g61t.org/forum/viewtopic.php?f=6&t=15805
Page 1 of 1
Author:  waxie1 [ Sat Nov 12, 2005 1:28 am ]
Post subject:  starting with no gearbox?
Is there a way to start a 4g63 without the gearbox on? I've tried and the starter is slightly off alignment. I could try holding it while a mate turns it over, but i'm too whoosie for that.... :(
Author:  unior [ Sat Nov 12, 2005 2:32 pm ]
the easiest way is gonna be to bolt a trans on man.... at least the bellhousing from a trans
Author:  netninja2001 [ Sat Nov 12, 2005 3:18 pm ]
yeah, it should take maybe 15 minutes if that to just get it bolted up so you can start it (though prolly less than 5 minutes with everything already prepped)
Author:  monsterbishi [ Sun Nov 13, 2005 3:05 am ]
Only way to do it without the gearbox to support the starter is to fire it up from the other end of the crank, have done it before with a decent ratle gun.
Author:  waxie1 [ Mon Nov 14, 2005 6:04 am ]
Wow crank side, thats lateral thinking! I'll have to wait for a mate to come over so I can get the gearbox into position. Thanks fellers!
Author:  boostfreak [ Wed Nov 16, 2005 6:35 pm ]
If rattle gun=impact driver, then that is very, well scarry!
Author:  monsterbishi [ Wed Nov 16, 2005 9:57 pm ]
Yep, Key thing to remember is to only put the tip of the driver in the crank pulley as far as the retaining bearing, any further and you can't get it out fast enough when it fires.
Author:  netninja2001 [ Wed Nov 16, 2005 10:06 pm ]
I'm gonna go ahead and post this before a newbie gets their hand/arm ripped off or something...
Perform at your own risk. The views and opinions expressed on this forum reflect the members views and opinions and are in no way shape or form condoned or endorsed by 4g61t.org, it's admin, or it's moderators.
there... now i feel better and can sleep tonight :P
Author:  monsterbishi [ Wed Nov 16, 2005 10:16 pm ]
:-) Just count yourself lucky I'm not sharing any of my home-made fireworks tips :-)
Author:  89coltgt [ Thu Nov 24, 2005 11:03 pm ]
You could always make a bracket that holds the starter on and bolts up to the block where the tranny does.
Author:  colt-r-old [ Fri Nov 25, 2005 1:28 am ]
Bolt the starter to the start plate and just hold it for reinforcement.
If you don't have a starter plate, put it on.
Author:  HondaHunter [ Fri Nov 25, 2005 2:04 am ]
im with unior, just use the bellhousing
https://www.phpbb.com/
