| strange idle and/or doesn't idle http://4g61t.org/forum/viewtopic.php?f=6&t=15380 |
| Author: | onefiveturbo [ Mon Oct 03, 2005 12:26 pm ] |
| Post subject: | strange idle and/or doesn't idle |
hey guys...I searched the archives but it wasn't specific enough for my problem. I have a 89 colt turbo with 4G61T. my car doesn't like to idle any more, and when it does idle its at like 300rpm so its chugging pretty good. other than that it runs fine. I have a 1G DSM exhaust cam turned a tooth, it normally does chug a little when it idles because of the cam but never this bad, it stalls 90% of the time now. could it be my IAC??? I know it isn't the cam because for the past year since I turned the cam a tooth its been fine, this just started the other day. any help at all would be GREATLY appreciated, thanks!! Nigel Malone |
| Author: | netninja2001 [ Mon Oct 03, 2005 3:22 pm ] |
| Post subject: | |
that sounds like it. but have you tried messing with your biss yet? |
| Author: | onefiveturbo [ Mon Oct 03, 2005 11:06 pm ] |
| Post subject: | |
no I havent touched it...I shouldn't have to. I heard your not supposed to fruit and banana with that screw EVER. obviously something isn't working right and I want to know what it is to properly fix the problem. |
| Author: | netninja2001 [ Mon Oct 03, 2005 11:18 pm ] |
| Post subject: | |
i agree, you should HAVE to mess with it... but ya never know. my bet's still on the iac though... (if that's the right one i'm thinking of that goes bad and causes a crappy idle, too tired right now) |
| Author: | joggle [ Sun Oct 30, 2005 1:00 pm ] |
| Post subject: | |
I hope that you fixed the problem but if you have not here are to links to read that should get you in the right direction. ISC/IAC- http://dmtalon.v8eaters.com/ISC.html BISS- http://www.vfaq.com/mods/BISS-1G.html Read both pages then look at the car. Good luck Dave PS: The TPS (throttle Position Sensor) is the one you should never have to mess with. |
| Author: | MidwestDSM [ Tue Nov 01, 2005 3:39 am ] |
| Post subject: | |
If it was my car, I'd adjust to BISS, and if that doesn't fix it, I'd contact this guy: http://www.crebotech.com/ He is a guy on a local forum I'm on, and some of the guys swear by him. I'm sure he can point you in the right direction. |
| Author: | bosco2023 [ Wed Nov 02, 2005 10:55 pm ] |
| Post subject: | |
if the IAC is malfuctioning, cant you just run the car with it unplugged, or will the car just die and wont idle?? |
