It is currently Mon Nov 03, 2025 4:16 am
PostPosted: Tue May 10, 2005 5:43 pm
Ok so i have just recently heard that some people have been cracking blocks by mounting an electric oil pressure sending unit on the oil filter housing.
I am working on a 90 awd
I guess I'm gonna look for a short section of SS line and a T fitting.....any ideas on where to find that stuff?
I do have the stock autometer adapters also that came with the gauge
TIA
90 GGSX
89 YX-600
92 Laser AWD
PostPosted: Tue May 10, 2005 6:30 pm
M10x1
LC '01 Accent GSI - Silver
PostPosted: Tue May 10, 2005 7:54 pm
It will be fine, i have the same setup....
Thread size for the housing is 1/8 BSPT. (british std. pipe) The sending unit is 1/8-27 NPT. The sizes are close, but I would just get a 1/8-27 NPT tap and rethread it while you have the filter off changing the oil. Brakleen is your friend :)
91 Colt GL "dandelion demon"
PostPosted: Tue May 10, 2005 10:08 pm
ok so its not m10x1???
now the next thing - i have a 1/8 x 27 brass TEE and male to male adapter
but im trying to figure out the best way to fit the stock sending unit and aftermarket one on there
i was thinking about mounting them both off the feed hole for the stock gauge sending unit location instead of the stock pressure switch sending unit location
(there is less room at the pressure switch location)
thanks for the input
90 GGSX
89 YX-600
92 Laser AWD
PostPosted: Wed May 11, 2005 9:30 am
Big heffer has broken off mine and many other people's housings when hitting a good bump. I have mine now mounted in a rubber oil cooler line to absorb impact.
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Wed May 11, 2005 12:31 pm
All I know is I bought an M10x1 senser from VDO and it screwed right into my block without issues.
PostPosted: Wed May 11, 2005 1:40 pm
alright i think i got it now
im using a short section of ss line BSPT to NPT adapters, brass tees, blah blah
what a pita
90 GGSX
89 YX-600
92 Laser AWD
