It is currently Sat Nov 01, 2025 3:45 am
 Post subject: Changing sensors?
PostPosted: Fri Apr 29, 2005 5:42 am
Of all the people who actually done the swap from a 1.6T to a 2.0T, who actually had to swap sensors? Please say which engine(90, or 91-94) and which ecu(90, or 91-94). Also post which sensors you had to change. Im trying to see if i have to swap sensors or not.
PostPosted: Fri Apr 29, 2005 9:54 am
Depends on the engine...Once you swap just place the two engine next to each other and compare the connections...That will be the easiestiestiest route...
PostPosted: Sat May 07, 2005 10:40 pm
If you have an engine from a 90, the sensors are the same, if it is a 91+, you can use your sensors off of the 4g61. If you use a 90 ECU, it is plug and play, if it is a 91-94 ECU, you'll have to swap two wires on the harness. You would have to swap all throttle body sensors and the CAS, if the engine is not out of a 90. Hope that helps :)
PostPosted: Sat May 07, 2005 11:15 pm
I knew about the 6+14 wires already, but is it really just thoes two sensors? CAS+ throttle body sensor? i know i have to change coil, but what else?
PostPosted: Mon May 09, 2005 12:25 am
The sensors themselves aren't really different, just the connections to them.
Things different between the 90 and the 91+.
Coil packs, 90's have a 4 pin plug, 91+ has 3.
Ign Transistor, 90's are smaller that the 91's, I think 5 pin to 7 pin.
CAS, 90's have a pigtail on them, 91+ the harness plugs into it.
TPS, 90's have a pigtail, 91+ doesn't.
Plus the ECU differences, but you knew about that.
If you have a 90 harness, then use all the 90 stuff. Same goes for 91+ harness/sensors. Changing that shit over isn't all that hard either, it'll take you maybe an hour max to do it if the engines are side by side.
Darin
1986 GMC 3/4 Ton 4x4 Diesel (soon to be Greasel)
1993 Colt GL
