It is currently Sat Nov 01, 2025 7:11 pm
PostPosted: Thu May 05, 2005 2:29 pm
Just curious as I have heard it is possible to machine the 14b housing to accept a 16g wheel. Anyone have any feedback on this setup? Seems like it might be an ideal setup for a 4g61.
PostPosted: Thu May 05, 2005 3:22 pm
yeah, we call that the "small" 16g
PostPosted: Thu May 05, 2005 6:15 pm
figured it was similar, if not the same. and with the 060 housing it should spool decently on the 4g61. thanks
PostPosted: Fri May 06, 2005 2:45 am
Actually, there are 3 different 16G wheels, maybe more. Small, Large, and EVOIII.
The compressor hosuing are a tiny bit different between the 16G's and the 14B as well, the 16G have a larger intake on them. You have to remove the rubber ring from the intake snorkel on a DSM to get it to fit.
A better bet is to buy a 16G and simply put the 6cm turbine housing on it.
Darin
1986 GMC 3/4 Ton 4x4 Diesel (soon to be Greasel)
1993 Colt GL
PostPosted: Fri May 06, 2005 10:26 pm
well which one is the best for quick spool time and high boost?
mmm boost :twisted:
White 92 1.5 Mirage R.I.P. summer 2004 junked.
Blue 91 1.5 Mirage R.I.P. $SOLD$
Red 91 1.5 junked.
Silver 94 Ford Thunderbird LX 4.6 V-8
removed intake silencer, K&N, 3:27's, open exhaust, custom intake. wating for a new trans.
PostPosted: Sat May 07, 2005 12:36 pm
They are all going to be fairly close.
My rule of thumb with turbos is to pick one you want, then go a tiny bit bigger as you'll always want more further down the road. Unclipped EVOIII 16G would suit you great! Buy the whole thing, but use your 14B 6cm turbine housing. Keep the 7cm housing to "grow into" :-)
Darin
1993 Colt GL
PostPosted: Sun May 08, 2005 9:27 am
Just bite the bullet and put a garrett setup on it like I did...lol :twisted:
'90 CSM Hatch 4G61T swap....lots of goodies.
PostPosted: Mon May 09, 2005 3:19 pm
mmm ball bearing turbos :twisted:
Red 91 1.5 junked.
