It is currently Wed Oct 29, 2025 11:28 am
PostPosted: Tue May 03, 2005 9:32 am
I can have a deal to get some DSM 90 shifter bushing in polyurethane.
I know the DSM 91+ are different from DSM 90.
Is there anyone know if shifter bushing from DSM 90 are fitting for colt ?
I look in the CAPS program to compare DSM 90 and Colt and the picture doesn't seem to be exactly the same. :-?
Thanks for your help !
PostPosted: Tue May 03, 2005 3:53 pm
well i have a 90 shifter at home, i'll take a look at it and compair it to the one i just installed a few weeks ago (still haven't put the center console back on so...)
PostPosted: Tue May 03, 2005 7:53 pm
4g61t Delinquent
back when i had my CAPS working on my computer, it may have been a glitch but appearantly the 3g Eclipse shifter bushings are the same as the CSM shifter bushing. so look up the shifter bushings for the 3G eclipse and click the button on CAPS with the hand tools. itll cross reference the parts and see what other cars use that part ;)
I own a CSM.
PostPosted: Tue May 03, 2005 8:49 pm
I just bolted that f'er right down to the floor. No need for bushings!
PostPosted: Wed May 04, 2005 10:18 am
If there bushing it for a reason. I'm fear if you don't use bushing you will use something in your tranny more fast then normally. Or maby the shifter cable will broke...
My guest, not a fact.
PostPosted: Wed May 04, 2005 11:56 am
nope, the bushings are there for nvh issues (noise, vibration, and harshness) it makes the cabin quieter, and smoother.
without the bushings (right to the floor) makes the shifter feel 100% better, and you can feel the gears engage.
PostPosted: Wed May 04, 2005 6:07 pm
without the bushings will the shifter assembly sit lower?? I say just replace with some washers or something...
PostPosted: Wed May 04, 2005 6:13 pm
Moving the shifter up and down won't change anything in regards to linkage stretching/movement. I realized why I broke so many shift forks and could never get into gear just a few months ago. I still had stock rubber shifter base bushings installed!
PostPosted: Wed May 04, 2005 6:14 pm
If you replace it with washers it might slide around on the washers. You either need the stepped bushing kit or bolt it to the floor.
PostPosted: Wed May 04, 2005 7:28 pm
or just lock-tite the washers! :D lol, btw, i'm just kidding, that prolly wouldn't work. best bet is the stepped washers (if you don't want to bolt it right to the floor that is)
PostPosted: Thu May 05, 2005 5:09 pm
i just picked up some washers that were close to matching the diameters of the bolts and the holes in the shifter base [ID and OD respectively] - they'll help you get it aligned more easily, but they're not under the shifter base.
worked well [especially for ~$.30], but wasn't a really big change in shift feel.
PostPosted: Thu May 05, 2005 11:14 pm
Just as important as the base bushings are these for the linkages at the trans levers.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33736
Normal skate bearings and washers work, basically the same thing. Night and day difference.
PostPosted: Fri May 06, 2005 12:58 am
4g61t Delinquent
ok got my CAPS to run again:
P/N MB580086
MR103559
(i dont know why it gives two numbers for this part)
other vehicles that share the floor bushing for the shifter are:
CJ2A
CJ5A
CK2A
CK5A
C52A
C53A(DUH)
C62A
C63A
D52A
D53A
E56A
hope that helps you boys out when looking for polyurethane shifter mount bushings :wink:
I own a CSM.
PostPosted: Fri May 06, 2005 10:21 am
Thats funny LilEvo, I did the same thing when i fabricated my short throw shifter. The base i used was from Elantra. The holes all lined up, but the shape wasnt quite right to sit flush with the bushings installed. Enter the "bushing elimination kit". :P The base has a slight slant towards the rear of the car which actually results in a more confortable shift position.
I agree, the shifter feels better bolted directly. The bushings just increase slop while absorbing vibration and noise from the transmission. 8)
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
