| Connecting tacho to aftermarket ECU http://4g61t.org/forum/viewtopic.php?f=6&t=13419 |
| Author: | cheeks [ Mon Apr 04, 2005 11:48 am ] |
| Post subject: | Connecting tacho to aftermarket ECU |
Hi everybody, I'm from Australia and have had so many dramas finding wiring schematics so I can connect the standard tacho to an autronic SMC. I am currently running an aftermarket item on the dash but would prefer to run the OEM one to keep my sleeper look. Any suggestions or links that could help me? |
| Author: | monsterbishi [ Mon Apr 04, 2005 5:08 pm ] |
| Post subject: | |
There's only two wires that need to be connected on the dash end, TM and TM ground, they have small screws going into them that you can undo and put a ring style crimp piece onto. TM ground just needs a good earth, TM goes to the tach signal wire that goes to/from the ecu. |
