any idea why was the original excel gearbox was kept in yours? Im trying to figure which would be the best option - swap the gearbox or keep the original. 4g61 box = stronger than 4g15 box, but the change might be tricky im guessing.
If its not overly complicated id prefer to use the 4g61 transmission, simply because its less likely ill break it.
Excel gearbox was mated to 1.6 non-turbo Lantra here, at least early ones. I don't think the 1.6 turbo churns out massive torque so perhaps it not such a bad combo. if switching to different tranny seems like getting shift cables right is much of the challenge.
I think ill end up changing rear brakes at a later stage as well, but how neccesary do you think this is? Ill leave it a while if it isnt hugely neccesary.
front is priority, rears couldn't hurt. it's been determined that the J1 GLS & CSM rear discs/hubs
should be an easy fit onto X2 rear. however it is still theoretical as far as I know, plus you need to alter or bend up new hard line since stockers hug the arm & go directly into drum cylinder.
In relation to the engine mounts, how much too high does the engine sit for the bonnet close?
if memory serves correct, I learned this through xlr8 - perhaps he knows more detail?
Other thing im trying to figure out is axles. Keeping the stock gearbox id be able to use the current axles, right?
But if i change to the 4g61 box, are there any axles from another car (lantra perhaps?) which would be able to be used?
I will say 'yes & maybe!'. it is speculation based upon observation, so take w/grain of salt. it seems as the the flywheel side of the 4G
xx DOHC block still sits in the same spot as the stock 1.5(compare t-belt mounts & block dimensions), so using stock grindbox & axles should fit.
is Lantra/CSM chassis w/wider track width than X2(i think slightly?)? if so then maybe axle lengths differ, but I know a-arms & knuckle is different, so maybe axles can still be same length?! if spline count is same then Excel shafts fitted to CSM/Lantra tranny can work? or Lantra/CSM axles & tranny fit to Excel hub/knuckles?!!
this is the junk I could never figure out for sure.
