It is currently Sat Apr 27, 2024 1:08 am
Post new topic  Reply to topic  [ 42 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Nov 02, 2004 4:19 am
Never thought to use 4g64 pistons before. Is there any stock ones that would make about a 8.7 to1 ratio?
89 Mighty Max 2.6. Lookin for side drafts 89 Colt turbo. SOLD
91 Galant GSX, waiting for 2.4
PostPosted: Tue Nov 02, 2004 1:24 pm
Any NT piston is too weak to put up with much abuse from forced induction. I seem to recall that the 4G64 DOHC pistons have a thinner dome than the stock 1G NT pistons.
If you're going to the hassle of boring the block, etc, why not use a decent set of pistons?
Darin
1986 GMC 3/4 Ton 4x4 Diesel (soon to be Greasel)
1993 Colt GL
PostPosted: Tue Nov 02, 2004 2:02 pm
It is what I call a lack of funds. I get a deal on boring, It will be like 60.00 for all the holes. Good pistons$$$$$$$$$$$$$$$$.
PostPosted: Tue Nov 02, 2004 2:20 pm
Then start saving :-)
Darin
1993 Colt GL
PostPosted: Tue Nov 02, 2004 2:33 pm
I would preffer to do a 63. Question, Can I run a 63 for a while with a 61 ecu?
PostPosted: Sat Nov 06, 2004 6:56 pm
Here some answers to some questions. The 4g63 /T intake manifolds have alot bigger ports than the 4g61 has. The differnces between the 2 intakes/head port size is as vast as the differnce from a 1g 4g63 head vs. a 2g head . They will bolt up but the ports are gonna be way out of wack. Also the 4g61t lacks piston oil squiters if I rember right. Using cast pistons with the lack of squiters, + boost with higher than stock comp ratio with pump gas in a street engine is a total time bomb combo. As many have stated u will be alot better off going the 4g63t route.
Lance
PostPosted: Fri Nov 12, 2004 8:54 am
Hey all, I lurk, but never post.
I have 9.0:1 CAST N/A pistons in my Galant VR-4. Running the stock IC, injectors, and MAFS. Currently set at 13psi on a 14b. I have had NO problems with this setup. I run my car hard sometimes, never had a problem. I did this due to cost measures as compared to getting the 2G/1G piston/rod combo. The car is A LOT more driveable when not in the boost, and I get 13psi by 2700rpm. I'd say run an IC if you were gonna do it, as I get knock at anything over 13psi.
I don't mean to step on any of the other guys' toes, as they all have good points. What are the differences in the turbo/na pistons? Are they different designs? Are they made of different materials? Mitsubishi Evo VIII's are running 8.8:1 pistons stock on an Evo 16g. That's pretty high compression for a turbo car.
So yes, in my opinion, you could run the N/A's. Get a good IC or run water injection. Then again, 8.0:1 is great for making lots of boost. The answer to your question really is:
What are you gonna do with the car? Then, go from there.
PostPosted: Fri Nov 12, 2004 12:56 pm
The crown on the NA piston is alot thinner than a turbo piston. The ring lands are also alot skinnier.
Darin
1993 Colt GL
 Post subject: Re: 2G pistons in 4g61
PostPosted: Fri Mar 06, 2015 9:41 pm
I know this is a vintage post but I'm new to the site I want to know how did it turn out for you ? Did you use the 2G piston in the 61 block ? I'm thinking about doing the same setup.
Hyundai Excel
G4cr na
PostPosted: Fri Mar 06, 2015 10:17 pm
FatBastard
Last visited: Wed Feb 09, 2011 3:47 pm
wink wink
PostPosted: Sat Mar 07, 2015 12:07 pm
Hyundai Excel
G4cr na
PostPosted: Sun Mar 08, 2015 10:13 am
Just mentioning that some of the guys in this thread haven't visited the site since they posted these comments, or shortly there after. Some posts were made in 2004 when I joined here 11 years ago. fatBastard last logged in early 2011. The guy before him was 2010 sometime.
