It is currently Mon Oct 27, 2025 12:11 am
PostPosted: Thu Jul 28, 2011 4:53 pm
The Wallz 255 flows more than the OEM pump... PERIOD. Please check your current pressure and advise of your findings.....
I understand that a 255 flows more than a stock pump.
The car has been running for 2 years with the 255 pump on a 1g FPR, why has it not had any driveability issue, IE: hard starts, incorrect plug readings, skip/mis, no black soot on bumper at all, etc.?
I understand that the fuel pressure will be higher than a stock pump, the plugs look perfect, the back bumper isn't black. At idle it has a mis to it, only after changing a timing belt that was 1 year old.
The car is my daily driver, never had a issue, and has never done this. I'm not trying to be difficult, but what I'm wanting to know is how could a pump that has been in the car for 2 years, all of the sudden be causing me my current issue, after a t-belt change (old belt, again was only 1 year old) with all marks correctly aligned??
PostPosted: Thu Jul 28, 2011 5:26 pm
We are going by process of elimination. Your exact problems have been caused by too high of a fuel pressure in my situations in the past. A miss/skip is caused by either your fuel or your spark. Check the fuel pressure and if it's the right pressure, we'll move on to the next possible problem.
PostPosted: Fri Jul 29, 2011 5:47 pm
No worries. If you know it's not the pump, then it probably isn't. Best of luck
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
