It is currently Sun Apr 28, 2024 1:12 pm
 Post subject: help with rims..
PostPosted: Fri Oct 04, 2013 12:52 am
I have put in over 20 hrs of searching in the past 2 weeks with no defined results just alot of.. u need this or u need that with no actual facts/proof to back it up...
ive checked all the 4g threads here and on mirage performance forum..
all the research I found says my 94 mirage es came with 14s.. it has aftermarket 13s on it now.
what I would love to know is.. what is the best size rim..15x7 or 16x7.... and most importantly the offset.. ive seen they use anything between 35-45.. I want to run something like a 205-50 or a 225-50 series tire.. just want to make sure it will fit and not rub on the fender or the strut.. will probably lower the car a lil but definitely not too much as the roads here suck..
thanks for any input/help on the offset/size.
 Post subject: Re: help with rims..
PostPosted: Fri Oct 04, 2013 8:21 am
I'm using a 15 x 6.5 with a +35 offset I believe. They look great with a 205/50 mounted on them. My car is lowered about 1.5" all around too.
PostPosted: Fri Oct 04, 2013 2:26 pm
that looks nice Chris.. seems every rim I find that I like (im a very picky person)... are either 40 offset or 10 offset.. im also looking at the 15x7 size should I look for 6 1/2 instead?
PostPosted: Thu Jul 10, 2014 10:14 pm
15x7.5 40 offset. 225/50's in front (DRs)
17x7 32 offset
17x8 40 offset 225/50is in front (DRs)
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Sat Jul 12, 2014 9:48 am
16x7 Tenzo Meister v2's +38mm offset with 215 45/16. The car ws lowered shortly thereafter with
Megan springs, and GR2 shocks all the way around.
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
