It is currently Fri Apr 19, 2024 10:33 am
PostPosted: Mon Feb 20, 2017 9:39 pm
I happen to have a blown 1g dsm awd transfer case... the previous owner of my Colt gave it to me, so I decided to rebuild it as a backup unit.
After tearing into it I discovered that the Tcase was in better shape then I expected apparently the bearings are wasted but the housing and gears are still use-able :D
as I tore it down I started to see bearing part numbers on the cups and bearings, so I decided to write them all down, and share them with members, just in case you want to order everything in advance to do the job.
Imagescreen capture
Above is a Mitsu CAPS image I'll use for reference.
[Number in picture above to reference location] [part number you might be able to cross at auto parts stores] [OEM #]
30461------------------------------------------------- # on bearing[LM67048]# on bearing cup [LM67010][OEM # MD717511]
30453-------------------------------------------------[32010XJ] [OEM # MD723636]
30307-------------------------------------------------[32009J] [OEM # MD718322]
30454-------------------------------------------------[32008XST] [OEM # MR967457 or MD718323]
You might be able to use these numbers to get after-market bearings from Koyo, national, etc.
Front oil seal on T case part numbers [Duralast # 1981] [SKF 11592] [TIMKEN 223014] OEM # MD723202 or MD703735
Rear oil seal, to drive shaft, part numbers [NOK AH1895E], [SKF 12736], Oem # MD701430 or MD701782
I got all the after market equivalent of these, unfortunately some National bearings are made in China[what isn't these days ], and it's hit or miss if you get ones made in, Japan, Germany, USA, Israel, etc.
Abe
PostPosted: Wed Feb 22, 2017 1:08 am
I went to AutoZone and crossed the part numbers, these should interchange with most other auto parts stores.
CAPS Image number. AutoZone cross reference numbers/ Brand/part numbers
30461------------------------------------ National [A-6] Duralast [SET6]
30453------------------------------------ Duralast [32010X]
30307------------------------------------ Duralast [32009XM]
30454------------------------------------ Duralast [32008XM]
Front oil seal,on T case ---------------- Duralast [1981]
Rear oil seal, to drive shaft------------ Duralast [223240] or [710317] I'm gonna find out which works soon enough.
Abe
