It is currently Fri Apr 19, 2024 6:57 pm
PostPosted: Mon Feb 17, 2014 5:21 am
Don't know if it has already been covered but has anyone ever tried an Evo III Crossmember in a 3G CSM for the AWD trans? I have one and will be test fitting it when I get back stateside and will be using it in my 4g sedan evo AWD swap but figured I'd give it a try first
91 Talon TSi AWD- SOLD
91 Mirage 4dr 4G63T -Daily
facebook.com/modicausmc
PostPosted: Mon Feb 17, 2014 11:36 am
If it doesn't bolt right in it will probably be very close. As far as OE pieces this is probably the closest to being a direct bolt-in; other than the Cyborg member of course.
PostPosted: Mon Feb 17, 2014 12:00 pm
Yeah when I was stripping the Evo it looked very similar. I'm assuming people don't use them because their hard to find... Thanks for the info I hope I find it bolts right up
PostPosted: Mon Feb 17, 2014 3:24 pm
3g's used the mounts on the engine block while the early evo's used the 2g style mounting points on the transmission case. I'm guessing it won't work but hopefully I'm wrong.
PostPosted: Mon Feb 17, 2014 5:47 pm
So the solution may be to employ a 2g transmission. Maybe the contact points will line up with the existing points on the chassis.
PostPosted: Mon Feb 17, 2014 6:57 pm
I almost want to disagree with that because it looked exactly like the one I use. I'll have to snag a picture and upload shortly
PostPosted: Wed Jul 16, 2014 8:11 pm
JDM evo 3 uses engine block for crossmember mounts
PostPosted: Fri Jul 18, 2014 11:44 pm
Are you positive about that? I thought they had the 3 mounts on the transmission case like a 2g dsm?
PostPosted: Thu Oct 02, 2014 7:56 am
Evo3 tranny has 2g style mounts.
Users browsing this forum: No registered users and 38 guests
