Evo III front crossmember for 3G http://4g61t.org/forum/viewtopic.php?f=57&t=38601 |
Author: | modicaUSMC [ Mon Feb 17, 2014 5:21 am ] |
Post subject: | Evo III front crossmember for 3G |
Don't know if it has already been covered but has anyone ever tried an Evo III Crossmember in a 3G CSM for the AWD trans? I have one and will be test fitting it when I get back stateside and will be using it in my 4g sedan evo AWD swap but figured I'd give it a try first |
Author: | CSM Shaun [ Mon Feb 17, 2014 11:36 am ] |
Post subject: | Re: Evo III front crossmember for 3G |
If it doesn't bolt right in it will probably be very close. As far as OE pieces this is probably the closest to being a direct bolt-in; other than the Cyborg member of course. |
Author: | modicaUSMC [ Mon Feb 17, 2014 12:00 pm ] |
Quote: If it doesn't bolt right in it will probably be very close. As far as OE pieces this is probably the closest to being a direct bolt-in; other than the Cyborg member of course.
Yeah when I was stripping the Evo it looked very similar. I'm assuming people don't use them because their hard to find... Thanks for the info I hope I find it bolts right up
Author: | 89Mirageman [ Mon Feb 17, 2014 3:24 pm ] |
3g's used the mounts on the engine block while the early evo's used the 2g style mounting points on the transmission case. I'm guessing it won't work but hopefully I'm wrong. |
Author: | CSM Shaun [ Mon Feb 17, 2014 5:47 pm ] |
So the solution may be to employ a 2g transmission. Maybe the contact points will line up with the existing points on the chassis. |
Author: | modicaUSMC [ Mon Feb 17, 2014 6:57 pm ] |
I almost want to disagree with that because it looked exactly like the one I use. I'll have to snag a picture and upload shortly |
Author: | BIGKERT [ Wed Jul 16, 2014 8:11 pm ] |
JDM evo 3 uses engine block for crossmember mounts |
Author: | 89Mirageman [ Fri Jul 18, 2014 11:44 pm ] |
Quote: JDM evo 3 uses engine block for crossmember mounts
Are you positive about that? I thought they had the 3 mounts on the transmission case like a 2g dsm?
Author: | pimpy rider [ Thu Oct 02, 2014 7:56 am ] |
Evo3 tranny has 2g style mounts. |
