http://4g61t.org/forum/
AWD WEIGHT
http://4g61t.org/forum/viewtopic.php?f=57&t=38152
Page 3 of 3
Author:  Flying Eagle [ Wed May 25, 2016 10:00 pm ]
Post subject:  Re: AWD WEIGHT
92 hatch, full interior, all glass, nothing was removed. 2978 with me in it (220)
Both USDM bumper supports, complete and in place?
LilEvo, your bumpers are Euro/JDM, so they have the thin (non 8mph) supports correct?
Author:  win0857 [ Fri May 27, 2016 1:40 pm ]
Yes, The only thing I did to the front bumper support is cut a hole for air but I reinforced it with 1/2" angle iron and I welded gussets from top to bottom in 3 places for rigidity( or stupidity) and then put the grill from a colt into the bumper. I also made a bracket for the intercooler in the support and the intercooler is very big. 3" piping and a 4"x 24"x18" core. I must be a good amount heavier than a stock original.
Author:  Flying Eagle [ Sat May 28, 2016 9:25 am ]
Wow, that looks really good! Haven't ever seen the head on shot before.
I can attest to the USDM front bumper support having saved the cabin portion of the car during a 90 degree angle collision with the front bumper/corner marker light area, at speeds of around 35 MPH/50KMH.
Front end moved over 6-12 inches, windshield still intact, and doors opened with little effort, which is surprising considering they don't when you jack up the car at one end. The bumper support was likely rotten too.
Author:  LILEVO [ Sun May 29, 2016 8:14 pm ]
The rear bumper cover is held up by a few strips of aluminum stock. Same as the front.
Author:  win0857 [ Tue May 31, 2016 6:33 am ]
Do you mean on my car? When I did the AWD I pulled the bumper, did the mustache bar mount with 2" square stocks welded rail to rail. I also made a fuel tank mount behind it rail to rail and then put the complete bumper back on.
Author:  Flying Eagle [ Tue May 31, 2016 11:13 am ]
Yes, your car. Lots of ingenuity happening there. You would never know to look at it. Very good work!
Author:  antilag_200 [ Mon Nov 07, 2016 11:24 am ]
Update on weight of my car which includes the following items
carbon fiber roof - saved 22 pounds
carbon fiber side rear quarter windows saved 15 pounds
car is awd and has two corbeau seats with 10 point chromoly cage , aluminum driveshaft, exhaust through the hood, no crash bars or interior pieces .
weight 2330
Author:  wrx110487 [ Mon Nov 07, 2016 7:19 pm ]
Nice... Mine is pretty much on par with yours mod wise except I have a sedan. 10pt. chromoly cage, aluminum driveshaft, no interior and two Kirkey's, Side exit exhaust and I'm at right under 2400.
Author:  antilag_200 [ Thu Sep 28, 2017 10:21 am ]
Update of cars weight at the shootout.
2555 ibs which includes the following
NHRA compliant 8.50 cage ( full ten point)
Parachute mount and assembly
lexan windshield, carbon roof and rear side panels
aluminum drag wing
nitrous system.
two corbeau seats.
manual transmission
puts the weight up to 2385
I am currently putting an auto transmission in the car, so I expect the weight to go up. I just wanted to place this information in here for those that are looking
Author:  cloead [ Thu Sep 28, 2017 8:01 pm ]
mine is 2720 with me in it (180lbs) and 13 gallons of 110 (~80lbs) so the car weighs roughly 2460 lbs.
Page 3 of 3 All times are UTC-05:00
https://www.phpbb.com/
